So I have been going through many many posts on Redline oil. Two questions remain as these are brought up continually in these posts. (1) Redline oil can harm the cats because of the elevated leels of ZDDP. (2) The esters used could potentially damage seals or cause the seals to leak.
My own take on this if you have a oil burner I could see the ZDDP damaging the cats though I am sure just the oil burning would also cause this. If these seals are already contaminated the cleaning done by the esters would uncover this exsisting problem.
I have used 10w-30 Mobil 1EP and I assume my engine is pretty clean. Does the cleaning ability of the esters in Redline and the PAO in Mobil 1 compare? Is one better then the other when it comes to cleaning?
The Redline is noted for its ability to withstand heat. In the winter with colder temps and possibly shorter trips would moisture in the oil be something that could occur more so then another oil. Sorry for the multiple questions.
