Never seen a non positive displacement engine oil pump...i.e.every revolution of the pump pushes out the same volume of oil.
Oil filter "flow rate" is completely meaningless in this situation, as the pump pushes the oil through the media at the same rate always.
Media gets too restrictive (clogged), and the pump pushes the filter into bypass (filter bypass)...same volume, but now dirty, ends up at the bearings.
If the filter can develop enough DP to allow the oil pump relief to open, then and only then will I accept that a filter can starve the wear surfaces.
(Above analysis ignores the fact that pump internal leakage increases with backpressure, but only tiny amounts in the pressures we are talking)
