RE the 14459 vs the14610 and the difference in media area... if this holds true of Puro or Wix, does it hold true in all brands when you cross reference?
I have one of each in the Fram Ultra line, an XG3593A (14459 cross) and XG7317) 14610 cross. Loath to waste two new filters, I enquired to Fram as to the media area difference between them. Unfortunately, I disclosed fully why I was interested and put them in the difficult position of not wanting to comment on installing a filter onto an application for which it was not designed. That said, I was able to get one spec... that there is only one gram of capacity difference between them.
My source also made the (good) point that if the filter were to fail for any reason and ruined your engine, it would be a lot harder, if not impossible, to make a claim because you installed a filter not spec'ed for your engine.
I'm not a "Chicken Littler" whose bowels go loose every time the specter of a denied warranty claim looms, but one must still gauge the risk vs the benefit. Is one gram of capacity, or 20 square inches of media worth the risk? You can decide that as I have.
I would still caution that just because one brand of filter shows this difference in filter area that the next brand will hold absolutely to that when you cross reference. I'm still trying to encourage my curiosity to fight a little harder against my cheapskate nature, so if I ever do cut the aforementioned Frams, I'll post the pics. In looking at them, looking down the mounting hole bore, measuring roughly, I don't see all that much difference in the amount of media between these two Fram Ultras. That remains to be determined exactly in a virgin autopsy, however.
