Terry Dyson's comment is that any small company does the best they can with capitol and marketing capability they have at their disposal. Small companies are hamstrung under that burden regardless of what is commonly thought here.
There is no doubt in my mind LC works as advertized but LCD has not paid me to do double blind testing thus I cannot meet the level of testing Pablo requests.
UOA accurately interpreted is the key, you have the baseline raw data catalogued here. Maybe Tony would like to hire me to interpret online, publicly a comparison, would be happy to do it.
UOA eliminates lots of bias even with normal automotive variability.
If UOA is not enough for you Pablo then you will not be happy with any proof. Your engine visual cleanliness testing should have been backed with UOA to see benefits. Like Auto-RX if the fluid cannot hit a surface it will take much longer for chemical vapor to clean what took 260K miles to develop. As a matter of fact the loose Volvo PCV system and ring sealing may have been a major contributor to the deposit formation, while using LC and Auto-RX type products would have slowed the vapor moving around in the engine, defacto slowing that cleaning you want to view. Maybe the oils and adds Pablo used over that 260K miles allowed deposits that are too hard to remove with any chemistry ?
Without UOA I can't say for sure.
BTW SS, LC is actually pretty high flash, very stable. 400F or so.
LC does NOT shear oil when used as directed. Unless you are loading 1/2 the oil volume with LC I cannot imagine and have not observed LC ever vis shear any fluid. Quite the opposite.
Here at BITOG you have many individual oil analysis, from different labs, that demonstrate gains in vis stability, lower oxidation,nitration,insolubles, and wear rates.
I guesstimate 1/2 my UOA customers use a "correction fluid" or fuel add now and if analysis and customer observation was not positive WE would change the regimen. I care about selling oil analysis interpretation/consult which results in HAPPY repeat customers, not sell fluids !
