I'm pretty sure the Prestone Quick Fill isn't low silicate. I believe it's the same stuff as is in the yellow bottles, but diluted 50/50 with water.
As a dissenting opinion, I believe the pre-mixed stuff has its place.
My heater control valve was slowly leaking recently, so while I waited for a chance to replace it I topped off every day or so from a bottle of 50/50. It does cost more; whether or not the labor of mixing coolant it saves is worth it is a personal choice.
For total flush/refills, I prefer the straight stuff. Usually, a "flushed" system is filled with straight water, and there's no way to get it all out. If you add 50/50, the final mix WILL be some lower concentration - there's no way around that.
Since you don't know the car's cooling system capacity, if you really want to control the coolant mix precisely you may have to guess and iterate.
Once you get the system filled up, test it. If the concentration is too low, siphon/drain some out and pour in pure antifreeze; too high, do the same and add straight water. Not exactly ideal, but it will work. Eventually.
My truck's cooling system capacity is just under 2 gallons (so, I use just under 1 gallon of antifreeze), as a reference point. I have no clue how this compares to the average.
