I've used PP and PUP for a number of years and, in recent batches, have found that there is less valve train clatter on a cold start with PUP. For that reason alone, I'll keep using PUP.
Is there any tangible benefit of PUP vs PP. My only concern is winter time, when upon startups engine receives the most damage. Would PUP benefit in better viscosity in the winter vs PP?
Pennzoil's syns are very thin, and they won't say why.
Pennzoil - Technology behind ‘Made From Natural Gas’ and Vehicle maintenance while driving less Q&A
Question about euro 0w40. SN+ and SP versions have different tech specs listed for viscosity, etc., but the product number is the same for both. Are they different formulations or the same?bobistheoilguy.com
Answers - Pennzoil Technology behind "Made From Natural Gas" and Vehicle maintenance while driving less Q&A
Pennzoil Made From Natural Gas Questions: In the process that converts natural gas to base oils, what percent of the finished base oil is the molecule or molecules you are trying to produce? Said another way, how pure is the finished base oil? The goal of refining is to make your end products...bobistheoilguy.com
And they come in a plastic bottle.They meet the specifications for their grade.
Exactly.Most oils have come in plastic bottles for a few decades now. What’s the point?
Exactly.
From (Joe) SonofSonof,If I recall correctly it may have something to do with the limited base oil viscosities available in GTL. They make grade, but yes thin for grade in 30 anyway.
You are one of many who have had oil consumption issues with PUP 5W-30, myself included.This is not an answer but an observation on the PUP.
I have a Hemi which consumes oil. The Platinum High Mileage 5W30 will go 3,000 miles and will still be in the safe range. The PUP 5W30 will need a quart added in only 3,000 miles. In short, the PUP goes through an oil burning Hemi fairly quickly.
We aren’t Pennzoil Customer Service. I’d contact them with this question.why pennoil not putting aluminum foil seal on their 5qt jugs? It comes handy when you buy it online, prevents messes during shipping.
If you message SOPUS they'll just basically blow you off and give you some kind've marketing spew answer. I'm probably sure a foil seal will cut into their budget too much.obviously. I was expecting some feedback. Maybe you need to take a chill pill
