Originally Posted By: Trav
The XP is a good filter, I don't buy into this efficiency hype tossed around on this board, in theory it all sounds good but in real world on the engine it seems almost meaningless.
Why do companies like Fleedgaurd and others make high efficiency oil filters for big commercial vehicles and tout how their filters cut down engine wear if there wasn't some kind of goodness achieved with better efficiency? It it all just "hype" in that world too?
Wix is one of the most respected filter makers on the market yet some claim there is an issue with the design that causes internal leakage. Are we supposed to believe they knowingly put junk, bad design or defective pieces on the market and do nothing to correct it?
Apparently, that was proven in another lab. Lies, conspiracy, false info ... guess people can decided for themselves.
Does all the oil go through the filter all the time? What happens when bypass pressure is reached, does unfiltered oil go through the engine? The filters bypass is much lower PSI rated than the oil pumps relief valve.
The oil pump relief valve and the filter bypass valve have nothing to do with each other. Tests done by Jim Allen here showed that filters rarely go into bypass unless you do something nuts like rev the engine up pretty high right away after starting it in below freezing weather. Or if the filter is really plugged up with debris which increases the delta-p to start with.
It would seem there are times in the engines operating cycle that unfiltered oil goes through the engine along with particles of every size. Take a new or clean engine that is broken in and gets regular maintenance, how many particles are actually being dumped in the oil? Does it matter if you filter 50% of nothing or 99% of nothing?
I'd rather filter 99% instead of 50% if I had the choice. Others may only like to filter out 50% of the crud ... that's cool if that makes them feel good.
Could it be that the supposed more efficient filter is more restrictive therefore allowing the filter to bypass more often? If this is the case the fact it captured 99% but allows all the particles to go through the engine because of bypass could actually cause more wear. I can understand why marketing is suspect here.
It's been shown that even a "supposedly restrictive" PureOne isn't really that restrictive. If the filter is designed right, it can be very efficient and flow well. A full synthetic filter will flow even better. Flow vs Delt-P with 5W-30 at 200 deg F. When oil if fully hot, the delta-p across most filters will be pretty low, and in that case the restriction in the oiling system is only about 1/15th (7%) that of the engine itself.
IMO there is possibly a error in the Wix spec sheet, even the Wix cartridge filter has the same 20 micron spec at 50%.
Many members have called the WIX Tech Line and spoken directly with a guy there, and have verified the XP efficiency as advertised by WIX is correct. It's not a typo. You'd think after they got a 100 phone calls and emails about it, if it was a typo they would have figured it out by now.
