Greetings all,
I have oil in my coolant. Don't know where its coming from, either the tranny cooler is leaking into the radiator or its coming from my engine. I will send a sample to Blackstone today if they check this type fluid sample.
I flushed the cooling system yesterday and the color of the coolant is somewhat red...trans fluid in tranny is not milky but is a little brown and will flush it all asap.
While waiting for results...what do any of you recommend?
I guess I better keep in mind that the previous owner may have put some junk in the coolant for some reason, maybe to me it looks like oil...???
Should I pull the rad and have a radiator shop check it, or go buy a pressure test kit, pressure up my radiator or cooler and see if it leaks...
Any suggestions will help.
Thanks, Eric
Thanks, Eric
