Fleet mechanic at work called me over to see "a great example of General Motors enginneeering"(my work area is right next door). He was changing the leaky power steering pump out of a 2000 GMC pick up and checked the oil(gas 350) and there wasn`t any
He was beside himself. When I first came over he said "when I say no,no means none,there is NO oil in this truck".
When it he brought it in he noticed the oil pressure gauge wasn`t working and thought it was broken,the truck was running quiet with no noises associated with a no oil condition. Turns out the gauge works fine
I asked him if any came out of the pan when he drained it and he said a couple of drops,just enough to get his gloves dirty. He said he thought he would have to use a screw driver to poke out chunks of crud but there weren`t any. I said I hope you put in 15-40 and he said he used 10-30, he said"you don`t want to give a starving man a steak",lol.
Just thought I`d share this story here. Should be interesting to see how the truck does. It may have developed a big leak some where just before he serviced it and he just happened to catch it before it seized up. At least you would think so
It only sees about 5000 miles a year and it`s probably going to be replaced soon because of age(maybe real soon
