Pretty sure is is still Mahle. web pagequote:
Does anyone know who manufactures Nissan oil filters?
Lots of Wix numbers going around here, I just want to get the correct one for fitment and the right bypass setting. It looks like the 51344 is the way to go on my 01 Altima, correct?quote:
Originally posted by unDummy:
Gasket size isn't what I use to determine filter "oversizing". Most engine filter mounts have an extra 1/4" or more in either direction.
Some imports can jump up to the 51626/51381 without leaking.
I've used both the 51344 and the 51347 on the 2.4L Altima. And, the bypass specs were perfect!
The oil sump is small in the Altima and is why I
won't use the 51334 or stock 51356. And, Nissan timing chains/tensioners/guides are weak. I'd rather have the filter bypass when needed to get oil pressure into the engine where I want it. This is why I won't use the 51568.
The rubber gasket on the 1334 (short wide) is identical in size to the 1356 (narrow tall). The gasket on 1344 is a couple of mm difference but is approx. the same length as the 1356 stock replacement.quote:
Originally posted by wymi:
quote:
Lots of Wix numbers going around here, I just want to get the correct one for fitment and the right bypass setting. It looks like the 51344 is the way to go on my 01 Altima, correct? [/QB]
