Originally Posted By: bobbydavro
Because many people like to compare PDS and some how use the values as a yardstick. It's not like nothing is there to hide, although for some reason yeh US PDS we're extra vague. You will see that PDS for US are now more like the global PDS used all around the rest of the world before.
I think you are assuming newer is better. Also you see to think BMW have some input in the formulation.
My point I'm trying to hint at is that BMW are likely to have chosen oil on price rather than performance, a 'new' 10W-60 only has to be ACEA now for BMW use. Just look at the branding for how much care they took 'twinpower turbo' on an oil for non turbo engines.
TWS is a well proven formulation in M cars and motorsport and is was developed when there was a Geniune technical requirement from the BMW hardware. The way it is formulated is rather unique and has some very good results in engine test. However without benchmarking its difficult to say how much better. I would imagine, from experience, it's a extension to an existing program.
TWS is probably the best formulation i have seen which is why I think i deserved a bit more credit.
Like someone pointed TWS was the standard as many other Castrol oils. Castrol 0W30 (that I swore into) was also one of those oils. Now? Nothing better or worse then any other oil in that class, whether you are looking PDS when new or more importantly UOA. For example only reason why I am using 0W40 castrol is availability, but I might give a try to new M1 0W40. Not sure why 0W40 would be any better then M1 0W40.
I am not at all discrediting TWS, BUT your answer why TWS is better then current 10W60 BMW oil is that BMW moved to that oil because of cost. What to say about Castrol and cost then? Also, who cares about what it says on bottles? Twin Turbo? So? All oil companies have their marketing all over the place with various name that sometimes do not make any sense.
I think we have to see some UOA from M models using this oil to make any kind of judgment. But what you saying does not explain why would TWS be better then BMW 10W60.
