I am building a huge vaccum in the heads. The vechile is stumbleing at idle and is running laborered. It astill has awsome performance off idle. Check engine light just came on.
When I remove the oil cap it takes quite a bit of force to remove the cap. The car is generateing a very strong vaccum. As luck would have it my vacuum guage is not working. I have very little experince trouble shooting GM powertrains. Is this normal?
In imports you always have an overpressure in the heads and get positive pressure comeing out of the heads.
I replaced the PCV valve about 7000 miles ago with OEM parts. It will only go in one way so it is not in backwards. I do not have any exhaust gas's in the coolant, no coolant leaking from intake manifold etc....
P.S. No oil consumption either.
