Originally Posted By: ShotGun429
Its more important that the Spindles are lubed reguarly than what grease you use. The failures i see are lack of mantaince.
On my JD front mow I put too much grease in the first time and blew the seals(?) 17 years later I had to replace the bearings in that spindle. The other is still good.
The spindle has two bearings and a 2" void between them that gets filled with grease.
