Originally Posted By: chrisri
Your BMW are specified for use of LL-01 because in NA petrol is of low quality. It's been said million times, I thought we passed this long time ago. If you were ever to make a switch to a low sulphur petrol, oil recommendations will change too.
I think we are having some confusion, yes, I mentioned that earlier in the thread too, that Euro cars sold here are spec'ing the "old" full-SAPS oils due to fuel quality (in fact, that was my first post that I think you replied to) which will not change in the immediate future.
However, these cars are designed to function properly (in areas with appropriate fuels) on lower SAPS lubricants, and that verbiage will be reflected in the owners manual.
On older cars, this will NOT be the case, even when sold abroad, and the statements I am seeing from the oil companies and manufacturers is to use an oil consistent with what is said in the owners manual.
One cannot simply assume that a 2001 BMW for example, in England, which specifies LL-01 in the owners manual, can safely use a lower SAPS oil just because the fuel quality allows it in newer vehicles. And this is consistent with the language from the ACEA. This is WHY I made the point about back-spec'ing earlier on, as if it was safe to do so, there would be documentation that calls/allows for it, similar to (as I already noted) the back-spec'ing to the 5w-20 viscosity in North America.
We on the same page now?
Yes we are
. Let us focus on a cars builders after 00-01. There's no point in discussing older cars because of their age and different fuel management system used in those. Diesels were completely different animals back then. Don't hang on strongly on that 06-07 year for mid/low SAPS oil introduction, it could happen earlier as I was writing by my memory.
As for your post about abnormal wear with use of C oils, we had a small Citroen van with 1.6 diesel which was on C2 diet as per specification. And sure enough camshaft failed, but can't remember precise mileage. What I found later on is that main culprit wasn't low SAPS formula, but rather low HT-HS of C2 oil. According to a PSA technician cars that used C3 oil didn't had those failures.
I can give you one example; my Stilo diesel is without DPF from factory ,and is specified for A3/B4 oil. Same car with exactly the same engine but with DPF use C3 oils. I guarantee you that engines are exactly the same.
