Originally Posted By: saaber1
AudiJunkie and river_rat, please keep the personal attack stuff off of this thread.
It's nice that you want to play moderator, but you don't really have the luxury of deciding what content belongs in the thread.
The origin of the engine in question seems highly appropriate, like it or not, as does my correction of the quip about it coming from Mexico, when it's in fact Hungarian.
Audi AG's 2.0L TFSI turbocharged 4-cyl. has had little trouble in the past winning over Ward's 10 Best Engines judges, garnering a spot on the list each of the last three years.
However, with the introduction of the all-new '09 A4 range, the auto maker tempted fate by trying to improve upon what already is one of the best I-4s in production.
ADVERTISEMENT
Fear not, as the revised TFSI turbo-4 once again fortifies Audi's pioneering spirit in direct-gasoline injection and variable-turbocharger technology by claiming its fourth-consecutive 10 Best Engines award.
While the aforementioned injection/induction systems, along with variable valve timing, a 2-stage intake manifold and electric-like throttle response, made last year's winner hard not to love, various improvements seriously up the ante for this mighty little 4-cyl.
Although the new engine eventually will work its way into numerous Volkswagen AG and Audi models, it currently does battle in a premium segment dominated by larger, more-powerful 6-cyl. mills.
For that duty, its 211 hp (at 5,300 rpm vs. last year's 5,000 rpm) comes up a little short. Yet, with modifications (including an optimized turbocharger; variable exhaust-valve-lift technology; revised electronic controls; a lower compression ratio (9.6:1 vs. 10.3:1); and refined internal components), torque jumps significantly to 258 lb. ft. (350 Nm) and comes in 300 rpm earlier. That's an improvement of 11 hp.
Engine type: 2.0L turbocharged DOHC I-4
Displacement (cc): 1,984
Block/head material: iron/aluminum
Bore × stroke (mm): 82.5 × 92.8
Horsepower (SAE net): 211 @ 4,300-6,000 rpm
Torque: 258 lb.-ft. (350 Nm) @ 1,500-4,200 rpm
Specific output: 106 hp/L
Compression ratio: 9.6:1
Assembly site: Gyor, Hungary
Application tested: Audi A4 Avant 2.0T S-line
EPA city/highway (mpg): 22/28
