Just some thoughts for those who are interested:
I notice that there are 1.2 million tires being recalled - produced over a 2 1/2 year production period. That means they produced almost a half a million a year. That's a HUGE number.
I also notice that some of these were supplied to Ford - and looking that up, it's E-150's. That's a bit of a surprise, as I would have thought that the light duty van would have P metric tires, the same size as the pickup trucks. Nope!!
These vans were pretty popular and that would account for the huge volume.
Having dealt with Ford, they are VERY sensitive to any recall type item - and no doubt pushed this issue strongly. They would have been aware of the failures through their dealer network.
Further, the problem with Ford (and any other OEM for that matter) is that once a tire has been qualified for use, they don't like changes. Any change has to be approved - and re-qualified, which is expensive. I can easily imagine that at the beginning of 2010, the tire could have been designed 5 years earlier.
I note with interest that the tire size involved was OE on E-150's since 2007 - and I wonder if either Michelin supplied the tires from the beginning (2007) and made a change in production in early 2010, or started supplying Ford with this tire starting in 2010.
It also appears that the Ford E-150 was discontinued with the last model being 2012 - coinciding with the end of the tire recall period. - and they haven't really replaced the vehicle yet. They do have a Transit Connect, but it is really a smaller vehicle and not at all like the full sized vans. A heavier duty vehicle called the Transit is coming in the summer of 2014 that appears to be a direct replacement for the E-series.
That means for 2 years, Ford did not have a vehicle in this category - so maybe my statement that these were popular vehicles is in error.
I also note that the tire is no longer available anywhere I looked, but I have to consider it might be because it has been pulled due to the recall. On the other hand, it has been a year and a half since the last recall tire was produced - and that might have been the end of production - period.
Doing some math, I figure that the early production (2010) failure rate was about 0.2% - which is about what I figured the failure rate was for the huge Firestone recall some 13 years ago. That would have gotten Ford's attention for sure.
This is the kind of thinking that I was expected to do before I retired. Management would have wanted this kind of insight - and I assume someone else is doing that as I write this.
