Originally Posted By: Daryll
Thanks. Good answer. What's in the 5W-20 extended synthetic that's not in the 5W-20 not-extended synthetic? And I assume the non-extended synthetic can still be more extended than dino? I'm NOT trying to be snarky but seriously am trying to sort out what's what.
There is not much, if any, difference in metallic additives so it must be base oils and/or non-metallic additives. One type of non-metallic additive that I'd expect is different in type or quantity are antioxidants. At least at one time period, "Supersyn" itself was a very high viscosity PAO used in low concentrations in regular & EP Supersyn M1. It was used in higher concentrations in EP oils. That could have changed since then. That very viscous PAO was meant to reduce wear, not make the oil last longer. I would not be surprised if use of Group 5 alkylated naphthalene and small amounts of esters differ between regular and EP 5W-20.
