Eiron
Hey guys, thanks for the comments!
Finklejag,
Yes, I think the Saab 0W-30 is an excellent oil, but perhaps not the best choice for a Saab turbo engine. A couple of things to remember:
1) Up until the release of the '03 9³ SS (& subsequent introduction of a fully synthetic oil in the US), Saab's primary recommendation for all turbo engines was an oil meeting ACEA A3. This new oil only meets ACEA A5 (unlike the other GM-LL-A-025 approved oil for US models, M1 0W-40). I suspect CAFE is the reason, since Europe still gets a Saab 0W-40 full syn.
2) This new engine has a 50% larger oil capacity than mine (6L vs 4L), so yes, stretching the OCI to 15k mi is a no-brainer for this model. I'm guessing the oil will last maybe 2X longer than in my car, since the heat & shearing abuse will be spread out & keep it "fresher". The extra additives also help it out here.
A turbocharger (& perhaps a Saab turbo in particular) is the embodiment of the term "High Temperature/High Shear." With only a 4L oil capacity, there's no way I want to use an oil with a low HT/HS rating. I agree with you, that this new Saab 0W-30 is a great oil, but I see it as being better for their non-turbo & diesel models.
Primus,
Dude! Glad to see you're still with us! Yeah, it's a little confusing for me as well. I've been using the same lab for all of my UOAs & VOAs. I suspect that the mixing of oils had something to do with the odd pattern in the additive numbers. (Maybe the milk jug added "extra nutrients"? OK, just kidding!) Maybe Mobil had a formula change? The oil I used came from a number of different stores & it was all loose bottles, so I'm sure none of the five bottles I used came from the same batch.
I asked the lab about the Oxi/Nit/Sul numbers, & they described it this way:
"Oxidation/nitration/sulfur products are based on how the engine is running. Factors that effect them are application, cooling system condition, topping off with a another oil, changing oil brands, temperature, etc. They change every time. We don't really trend them; they are more a snap shot of the engine at that specific time."
Does this info help?
Finklejag,
Primus,
