another snake oil...You tell me. That is why I submitted this for others opinions,etc,
Doesn't do any cleaning, will help prevent additional deposits though. I included the emails in my VOA thread referenced above from Lubegard's tech line. And yes, it's identical to BioTech, just in a bigger bottle for truck/semi customers. That's in the emails as well.I''l bite. Simply put, it boosts moly, the good moly, not MoS2,and does some cleaning. At least that's what they claim. It has a decent following here.
I spoke with them a few years back. They told me basically everything you said, the only difference was they claimed it did do some cleaning. I guess it depends on who you speak to or who replied to the email. Their literature claims it frees sticking rings. "Helps reduce smoking by restoring flexibility to valve stem seals for improved sealing, also providing outstanding upper cylinder lubricity as it frees up sticking rings."Doesn't do any cleaning, will help prevent additional deposits though. I included the emails in my VOA thread referenced above from Lubegard's tech line. And yes, it's identical to BioTech, just in a bigger bottle for truck/semi customers. That's in the emails as well.
The sample doesn't tell much if anything of value IE base blends etc. I could be cheap oil with standard additives added. Give the additive a try and report back if the butt dyno shown an improvement.Lubegard Heavy Duty Engine Protectant VOA
OK, so I know this is not a "PCMO/HDEO" VOA but there's not a spot for additives. There is a VERY old VOA of Lubegard Bio/Tech on the board, and there have been comments here that the Heavy Duty may or may not be the same, and may or may not have esters etc. I know VOA won't show esters but...bobistheoilguy.com
The secret sauce is the keyAlso adds a small amount of the sperm whale oil substitute.
