Originally Posted By: 2010_FX4
Originally Posted By: Pop_Rivit
That assumes that you're willing to settle for the cheap CFL and their long warm up time and poor color rendering. It's also important to note that there are a number of styles in which CFLs are not available, not well suited for, and non-dimmable CFLs should never be used with dimmable switches. Needless to say you won't find either dimmable CFLs, 3 way CFLs, or GU10 CFLs in your 88 cent price range, and converting switches and housings over increases the cost.
Until LEDs reduce in price--CFLs serve my needs just fine, there is no way I am going to shell out hundreds of dollars on LEDs. I have not experienced LONG warm up times with CFLs (likely due to the fact the temperatures in Houston are above median most of the time) and the lights that have dimmers are not frequently used so incandescent bulbs are still in use there (with spares in the stock). The ROI for LEDs in my case would be close to the 5-7 year mark versus CFLs and a lot will change in that time span--namely the cost of LEDs.
Same here. I compared cost last night of CFL and LED's. I can get a 8 pack of CFL's for $14 and 6 pack of LED's for $44, 13 watt for the CFL and 9.5-10 watt for the LED. Going to take along time to recoup the cost versus CFL! I've been using CFL's since 01-02 and except a couple bad apple's most last a long time. I put some in our current house when I moved in late 04 early 05 and all but 2 are still going.
Now for the RV that's another story.. switched out 20 bulbs for LED's for less than $40. Since we parking lot camp on occasion that really conserve's the battery.
