Originally Posted By: Warstud
Originally Posted By: dlundblad
I've always been told to replace them as conventional bulbs fail to keep the up front costs low and minimize wasting perfectly good bulbs.
I agree...it's a waste of perfectly good bulbs. Also I could see replacing the bulbs in the rooms that you spend the most time in but not all of them.
Many of our bulbs are in a fairly high vaulted ceiling. I don't care to drag the 10' ladder out a couple times each year to change out one or two failed conventional bulbs. I also don't want different colored bulbs during a transition period-our living room/dining room has a total of 23 bulbs in the ceiling pot lights and fixtures. Changing them over one at a time could have taken years, during which time I'd still be using significantly more electricity with the standard incandescent bulbs. Changing them all at once solved those issues.
Since we also have seen substantial savings on our electric bill, financially it makes sense to change them out en masse. There are a couple guest bedrooms that don't often get used, so we didn't replace the bulbs in them. However, the rest of the house gets used frequently. And since we often entertain large crowds, it's not uncommon for 50 or 60 bulbs to be on all evening (outside, hallways, dining room, living room, kitchen and lower level).
Originally Posted By: 72te27
Pop, thanks for this analysis. I've been thinking about when to make the jump, and your experience gives some good context for the financial side of it.
Where did you purchase your bulbs, if you don't mind me asking?
The Cree bulbs were from Home Depot, the remaining bulbs I purchased on Amazon. My original post is at
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3253159/LED_Bulb_Review#Post3253159 and that has the prices, type of bulbs, and initial impressions including why we went to the Cree TW series in the master bathroom.
Originally Posted By: Propflux01
Has that $28 a month savings negated the cost of 89 new led bulbs? I know those things are pricey.
It will take around 3 years to recoup the initial investment in bulbs. Assuming (and I fully understood the risk when I purchased them) that the lifespan is close to the manufacturer's claim, they should give me 5-7 years of use after the initial investment is captured in energy savings. So far I'm about 1/3 of the way to recouping the initial investment. The energy savings is difficult to perfectly measure since there are so many other variables on the bill, so my savings estimates of what I've saved so far are erroring on the conservative side. Many months the bill and energy used are significantly lower than the same time last year, but there may be factors other than the bulbs. That being said, I have not had a single bill in the last month that is even close to the same month last year, all have been lower, and some months significantly lower.
Originally Posted By: Al
Personally I really like the "Daylight" (5000K ) ones. Its a white light and not dingy. They taka a minute or two to reach full intensity. Goes with the territory.
Their life in not remotely as long as advertised.
The Cree bulbs that we have in the 5000K color come on instantly. I can't yet speak to the longevity, but I have not had to replace a single bulb in the year that I've been using them.
Originally Posted By: bigt61
Bang for the buck, it's tough to beat a CFL. The LED's definitely have a nicer, brighter light. For a closet that just gets turned on occasionally, I'll stick with the el cheapo incandescent.
I don't care for the issues associated with CFL bulbs. The slow warm up, lack of dimmability, and overall poor quality made it a no brainer to bypass them for LED bulbs.
Originally Posted By: Rick in PA
I put one in my old style Trouble Light, no worry about breaking the filament or burning myself on the hot reflector.
I have two of those type of trouble lights out in the shop in which I put two of the 5000K Cree bulbs. I genuinely appreciate not getting burned on the hot reflector, and the Cree bulbs seem rugged enough so that I have yet to break one when the trouble light slips and hits the concrete. The 5000K color works well when working under a vehicle.
Originally Posted By: Cutehumor
1000 bucks in LED bulbs I bet. I don't doubt that LED bulbs are better than CFL. It's about the $$$
Somewhere around $900 if I remember correctly. So far I'm about 1/3 of the way toward recouping that investment.
