Klasse sealant
North Carolina
I'm thinking of using the klasse sealant on my white elantra( 2013 model, but it was built 12/12 so the paint has gassed out).
If i use the klasse sealant, do i have to worry about andy plastic trim? There is black trim around the doors and mirrors. I will be applying by hand. Any suggestions?
I have used Klasse AIO and SG and dont recall issues on plastic. In fact, Ive used AIO on things like headlights and tail lights.
that should have read built 04/12
I've seen on some forums, that using the aio is a good idea before the sg. Is that what you did? Should i use a polish first just to make sure its clean?
You should clay the paint prior to Klasse SG. A polish would only be needed if there are marks/marring in the paint which white hides well anyway. If you apply the SG too thick it will make for a long day trying to remove it.
AIO is more of a non-abrasive chemical cleaner than it is an abrasive polish. For fresh paint, I would agree with the previous post: Clay bar followed up by the SG should work well.
Apply the SG thin, thin, thin!
I've never used the Klasse SG, but I have AIO and have to say I rarely use it. I think there are better stuff available. Just my
I used the klass this weekend, the all in one, then the sg sealant. A little does go a long way. I like that it does not discolor trim. It does not feel slick like wax. It will be interesting to see how long it lasts.
