Originally Posted By: Johnny2Bad
Originally Posted By: rikstaker
So the OP can determine the base stock of an oil by smelling it?
You might, if you are around a lot of oils and have continuous experience. When I was in the Pro Audio field many years ago, I could easily tell you exactly what tape was in a bag by smell. The go-to open reel tape for studio use at the time was Scotch 456, but Maxell, TDK, etc all had distinctive smells. The smell was subtle enough, though, that the tape had to be in a bag for there to be enough "smell" to do the trick.
Human sense of smell is quite powerful, but typically needs a bit of training to determine subtle notes. But I would not be surprised to learn some could apply that to oil.
You can open a bottle of TGMO 0W-20 SN yourself and you'll find that the odor of TGMO 0W-20 SN is quite unusually intense. I had mistakenly speculated it as being as PAO but after all PAO should have little odor as it's a paraffinic compound.
The odor certainly seems to be of naphthalene. Alkylated naphthalene is a type of Group V base oil made by ExxonMobil. It has extremely beneficial properties in comparison to Group IV and other Group V base oils. They offer very high pressure - viscosity coefficients, meaning very thick oil film in the elastohydrodynamic-lubrication (EHL) region. They also offer excellent lubricity (ability of an oil to lubricate or stick to metal surfaces) and solubility. They are also extremely resistant to oxidization.
Therefore, my current thinking is that TGMO 0W-20 SN is a mix of Group III (perhaps Group III+) with Group V alkylated naphthalene. If it's true that TGMO 0W-20 SN has Group V alkylated naphthalene, this is yet another huge quality advantage of TGMO 0W-20 SN over other synthetics in the market, making it a uniquely top-quality oil.
Here is a discussion of alkylated naphthalene from a recent post of mine:
Alyklated naphthalene is a truly excellent Group V synthetic base oil, surpassing Group IV PAO and Group V esters in many ways. They are very stable and they have excellent P - V coefficients, even larger than Group I, comparable to naphthalene. They also have good lubricity and solubility. They don't suffer from potentially high wear problem of Group V esters (due to the ester's blocking of the AW/EP/FM additives). (See this
reference.)
However, their viscosity indexes are very low. For example the the 5 cSt (@ 100 C) Exxon Mobil Synnestic 5 has a VI of only 74. (See the
ExxonMobil synthetic formulations guide.) Because of this reason, they cannot be used on their own in multigrade oils, which would require too large concentrations of viscosity-index improvers. Also, interestingly, the previous ExxonMobil formulation guide examples had used an alyklated naphthalene in their PAO blends but the new guide mostly uses an ester in their PAO blends. (You don't want to have pure PAO base stocks [or even pure GTL or Group III] because of their poor lubrication properties as explained earlier.) Use of alkylated naphthalene vs. esters in the examples may be due to changing marketing strategies more than anything else.
Incidentally, TGMO 0W-20 SN seems to have a fairly significant concentration of alkylated naphthalene, as I can smell the rather intense odor of naphthalene from the bottle. I don't know if it's used as a base oil or a pour-point depressant. I would very much like to have alkylated naphthalene as a base oil in my motor oil because of its superior pressure - viscosity coefficient, lubricity, solubility, and other properties.
