This is an oil filter my friend cut open on his car... any ideas/thoughts? The engine has a slight ticking noise.
Quote:
The ticking noise was present for awhile but the car drove fine. After the blower install the ticking noise got louder. Those are aluminum metal shavings in the oil filter.
It's possible the motor simply had bad timing chain tensioners...that's a fairly common problem...but since your friend continued to drive it, especially if he drove in a "spirited" fashion after installing the blower, then yeah...I'd say that motor is now one step from being a boat anchor.Quote:
gen 1 Mark VIII 4.6 DOHC motor
