A paraffin hydrocarbon is also called an alkane, and can be one of any of the saturated hydrocarbons having the general formula CnH2n+2, C being a carbon atom, H a hydrogen atom, and n an integer.Curious-does/should an oil containing paraffin preclude it from being labeled as a full synthetic?
It sounds like you're in Germany. Over here in the US and every other country, everything API Group III and above is legally full synthetic. Over there in Germany and only in Germany, only everything API Group IV and above is legally full synthetic.Tnks for the replies. I would like to keep the question brand non specific if at all possible.
For cost reasons, as an experiment, I recently switched to a different oil, brand name, labeled -full synthetic- I learned after the fact that it contains paraffin (does not qualify it as being synthetic paraffin) the brand which I switched from makes it a point to identify paraffin as undesirable, especially in an engine oil which is promoted as being full synthetic.
I became curious as to whether or not paraffin indicated other than a 'synthetic' formulation; hence the topic.
Now you know.I became curious as to whether or not paraffin indicated other than a 'synthetic' formulation; hence the topic.
Now you know.
Already answered.I know more than I did AND found a great thread on this site on this very topic BUT the conundrum remains:
which is the true synthetic-the one with or without paraffin ?
Twice.Already answered.
What is the point of bringing up past history whether it’s 1999 or 1977?
A lot has changed since then.
Not really -terms like 'legally synthetic' and an article ('99) which begins with: 'While the field is not wide open, a new ruling confirms that the definition of "synthetic oil" remains largely in the hands of marketers" pretty much confirms that the old advice is still the best advice: caveat emptor .
Again- thank you all for the replies.
So you weren't really interested in a technical (and slightly chemical) answer about paraffinic compounds, you were instead interested in trying to reignite the oft-debated "what's a real synthetic oil" debate?Not really -terms like 'legally synthetic' and an article ('99) which begins with: 'While the field is not wide open, a new ruling confirms that the definition of "synthetic oil" remains largely in the hands of marketers" pretty much confirms that the old advice is still the best advice: caveat emptor .
You never really explained your understanding of paraffin or "paraffinic" and you seem to be relying on marketing language, rather than the science of organic chemistry, to shape your understanding of the term(s).For cost reasons, as an experiment, I recently switched to a different oil, brand name, labeled -full synthetic- I learned after the fact that it contains paraffin (does not qualify it as being synthetic paraffin) the brand which I switched from makes it a point to identify paraffin as undesirable, especially in an engine oil which is promoted as being full synthetic.
