Originally Posted By: electrolover
Originally Posted By: HTSS_TR
Your car is under warranty and your driving is severe, you should change oil at 3750 miles or 6 months whichever is first, therefor you should use quality conventional or the lowest cost synthetic you can buy on sale.
+1 i would go with SN dino at that oci, and it will be as clean as any synthetic engine.
motorcraft blend would also be cost effective
I see that others have voiced their concern over the DI engine and the possibility of more intake deposit build up if an oil with a higher NOACK volatility is used. Do you believe this is an issue?
I saw the Motorcraft Syn Blend at Wal Mart. Might try that next time. Thoughts on the Mobil Clean 5,000?
