Thanks for the list of questios Molakule. I'll ask Mecacyl about them as soon as I get a reply for my first message.
Digging further in the topic of oil additives, I found that there are the following categories:
- PTFE: slick50...
- Petroleum distillate (containing chlorine): Duralube, Prolong....
- Molybdenum Disulfide: Moly-slip
- PP Formula 7
The last group seems interesting
"PP Formula 7. Discovered and patented in 1979 by a Boeing aircraft engineer, it is a process where different formulations of petroleum additives are re-synthezised and tiny, dense, round molecules of about 0.1 microns in size are created. The only product I personally know that uses PP Formula 7 is Petron Plus. However, it is very well possible that Militec uses the same formula. But I don't know that for a fact.
Formula 7 is the most promising oil additive as of today. However, it is beyond my knowledge in how far independent tests have been made to support the manufacturers claims, but there is one test known as load test that at least Petron Plus has passed with flying colors.
The re-synthesized petroleum molecules of PP Formula 7 are specifically designed to be used in combustion engines. They have undergone a significant molecular transformation. Their size is too small to be filtered out.
These magnetic molecules are very dense, so they have a high load factor wear. Their spherical shape gives them the highest shear factor in the industry for reducing friction.
Other than most engine conditioners that contain mostly a single-grade motor oil as a carrier of the solid particles, Formula 7 does not use any motor oil. Therefore, it is compatible with any kind of motor oil you use in your engine. It has been approved by OSHA, EPA, and COSHH regulations."
source:
http://brickboard.com/ARCHIVES/1998NOV/20017664.shtml
Well, this is again and again not something that will tell us if these additives are good or bad but it's interesting because it seems there are 2 types of chlorinated additives:
- Petroleum distillates (chlorinated paraffin etc) such as Duralube and Prolong
- PP Formula 7 as the guy who wrote this article believes (without proof) that Militec-1 belongs to this group.
The main difference I could understand between these 2 groups is that PP Formula 7 are REACTED products. They are not a mix of different things "only". This is quite important because either Mecacyl, Mecarun and Militec claims that their product is reacted and becomes a PURE and UNIFORM ORGANICALLY BOUNDED SUBSTANCE!
What I want to say is that maybe the conclusion that chlorinated compounds can be corrosive is true but is based on the Petroleum distillate group additives. Maybe if Mecacyl, Mecarun and Militec really belongs to the PP Formula 7 and thus are REACTED products, they may behave differently.
Is this absurd? Do you have more information about what are these PP Formula 7 additives?
