Originally Posted By: Spetz
I've been unable to diagnose the miss though.
The car has had new:
Air, fuel and oil filter
New spark plugs, leads, distributor rotor and button
Ultrasonically cleaned and tested injectors
Hooked up to a diagnostics machine and all sensors were reading fine
The only thing that seemed to have made the idle better (but not the vibration in the 1,000-2,000rpm range) is replacing the EGR solenoid. I then have tried blocking the EGR all together but this made no effect on idle.
What is the misfire count for each cylinder? Is one higher than the others, they all should be zero. A weak coil can cause problems.
