This. Glue the heck out of it, maybe some JB Weld. Put masking tape on the handle and use a razor to cut out the hole so you don't make a mess.If you never need to remove the screws ever again you can coat the screw in 5 min epoxy and use a toothpick to stuff some in the hole. Some will squish out that you can wipe up with alcohol while its wet. They wont come out without the wood attached. If you need to get them out you can use wood glue to glue broken toothpicks into the holes. Give it about 2 or 3 hours to dry before putting the screws back in.
In wood?Red Loctite should've worked, Are the threads pulling out?
My father, a wood worker, taught me the tooth pick trick when I was a kid. We didn't have to use over sized screws, though. I also learned to drill the hole larger an glue a dowel rod into the hole(s). when set (dry) drill a new hole for the screw(s).I usually just put in some toothpicks and keep snappin'em off till I can't put in anymore. Then get a slightly longer and/or maybe oversize screws and call it a day. Yeah, you could buy some inserts too but they often just spin in the holes.
All the woodworking tricks, and comments on how Loctite doesn’t work on wood, are missing this point.This is the original door and screws from 1994. I really can't completely tighten one of the screws. I was hoping the locktite would work.
The screws are going into a metal sleeve on the outside handle.
I'll take it apart in the next day or so and so you what the insides look like. I may have a bigger mess....LOL
I’ll get you picsTo clarify - are they wood screws or metal screws threaded into the handle outside? Makes all the difference in the world.
All metalIn wood?
That is correct.All the woodworking tricks, and comments on how Loctite doesn’t work on wood, are missing this point.
The screws are going into the other handle. This is a threaded, metal fitting.
