Originally Posted By: DoubleWasp
Have the same thing.
After the recommendation in the other thread of getting the transmission hot before doing the exchange, I asked around and got more recommendations to do the same.
I just start worrying that with cold fluid being fed into the trans that it will stop flowing as much and start recycling the dirty fluid.
I suppose if one were to get the trans good and hot, the thermostat wouldn't see cold fluid until the very end, and even that fluid will be heated by the hot internals. Just wish I had a solid confirmation on that.
Were I to do a flush that way, then enters the problem of continuously feeding the trans it's fluid through the sorry fill plug inches from the flaming exhaust while this goes on.
Lot easier for the later 6R80 guys who get that nice little hole with the tiny dipstick toward the front of the trans.
I wonder if draining it hot, and filling it with a magnetic oil pan warmer plugged in, fastened however possible if the pan is non-ferrous would help eliminate the thermostat issue you're concerned with. Possible food for thought. They sure aren't making these transmissions easy to service.
I have a Wolverine oil pan warmer on my Jeep's transmission. If I had the same concerns I would plug it in before filling the transmission.
