Originally Posted By: Leo99
Originally Posted By: MaximaGuy
Honestly, it isn't that straightforward. The pan has a drain bolt that drains the excess ATF, the level check is a small plastic thingy threaded above the drain bolt. Unnecessary hi-tech gizmo when a dip stick would have done the job.
My new Camry doesn't even have a proper drain bolt. I've watched the youtube video twice on how to remove the front left wheel and access the bolt holes but it's still not clear to me. I'll likely never touch it and let it go and see if it will make it to 300k miles.
I thought the fancy bolt thing was for checking fluid level *when not at the magical temperature*. Toyota (Aisin?) wants the fluid checked at a small window of temperature--and for some reason it's not at the typical 180F or so. By using the gizmo you can check fluid level at full temperature instead of the 115-130F IIRC.
My Tundra, last I looked, did not have one of those gizmos to check, at least not yet. So I took my truck for a quick spin around the block to get into the 115-130F level. The trans keeps temperature pretty well, so I was in no rush to level off and then check level.
I'd much prefer a dipstick but at least on my truck it isn't that bad, to check anyhow. Draining quarts out though is a bit harder, I haven't mastered that one yet.
