It depends on how expensive this is to you in time and money.
If its just toyota type t IV and takes you just 5extra minutes while you do your own oil change then every 2nd or 3rd oci can make sense.
So even though 30k should be more than fine, doing it every 15k or more often makes sense if fluid change history is unknown, and because it is so cheap. Just like getting new valve stems and valve cores with new tires even if the old ones could be reused. Or changing the oil filter even though it could go longer because you already are under the far and its all jacked up
But id you have to go out of your way and pay 60 and 2hrs then definitely not worth it to do it under 30k miles. Spend that time and money doing something else or on other maintenance you csn obsess over
