Originally Posted By: fdcg27
Rarely.
If a car is leaking anything, you'll see it where you park it.
If anything odd is going on, you'll hear it.
For engines that leak or burn oil, you'll know it and will check as needed.
Operating the hood release obsessively will only wear out the cable prematurely and cause it to break.
Good luck with that.
That's pretty much how I view it. If the car isn't leaking or using oil, no odd sounds there's no reason to obsess over it. OTOH if you have a problem you check more often.
Rarely.
