Originally Posted By: rationull
I wanted to follow up on this ........
Thanks. Most of the time, we never find out what happened. Not only is there a learning experience for us, but it's good for us to know that at least some of the time we've been helpful. Makes us want to help some more!
- Front toe was off and camber near the edge of spec on one wheel.....
So a combination of bad camber and bad toe did not produce a pull. This is an important lesson!
- Steer ahead was out of spec (I don't even know what that means though -- haven't looked it up yet)......
I assume this is "Thrust Angle" - and having the camber out of spec will cause this.
- NOTHING out of spec on the rear!
Both rear wheels have -2 degrees camber. This is not adjustable, and is within spec (range is -0.5 to -2.5 degrees). Rear toe was even at 0.04 inches on both wheels which is in spec. The shop increased the rear toe to 0.07 inches to try to prevent more wear. Max spec is 0.14 inches......
The rear camber might not be out of spec, but the SPEC is HUGE!!!! Way too high for good tire wear.
You have 2 choices: Live with the tire wear, or adjust the camber (yes, it can be adjusted!) and lose some handling.
Here's my recommendation for alignment specs:
http://www.barrystiretech.com/alignmentrecommendation.html
In this case you want the camber as listed. Be sure to compare to the front camber spec for a good comparison.
......I'm wondering now if this was more the result of a couple of long rotation intervals combined with the rather extreme rear camber. IIRC I have heard of that happening with other Mazda3s, especially with the OEM Toyo tires. I'm going to keep on top of the rotations from here on out (with the exception, I guess, that I'll do the first rotation 2-3k miles from now with an oil change) and hope this doesn't happen to the new tires.
Regular rotation will help, but the cure is going to be getting away from that severe camber. Again, there is a price to be paid.
