Took my 2001 Accord in for the usuall oil change and "multi-point" inspection at my local Honda dealer. I have a Die Hard Gold battery from 2008 they said "needed" to be replaced. I opted to do some research first. Even though I didnt buy my current battery (previous owner did), I would assume the 3yr free replacement warranty would still be valid.
Anyways, the dealer stated my battery was at 427 CCA (a new OEM battery has 490 CCA). No problems starting, cranking or with electrical. Charging system works well.
So here's my question: Is 427 CCA so huge a difference that the battery should be replaced today? To me, it shows the battery is simply loosing charge (as expected) over it's natural life-span. But replacing it seems premature. Thoughts...
