Originally Posted By: Ducked
Originally Posted By: gathermewool
This was especially nice when I was trying to discreetly change my oil in the parking lot of my previous apartment. It literally took me a minute to get in and out, before anyone could even think of complaining (or even know what the heck I’m doing, for hat matter - car needs to be jacked up for an oil change, right???)
Hadn't thought of pervasive non-permissive surveillance, because I don't live in that kind of environment, but I guess its a growing trend. Could certainly be an issue in the UK.
Here people tend to mind thier business, plus DIY maintenance is so unheard of that they'd never think to have an actual rule against it.
IIRC I dont need to jack up using a conventional drain plug, but I suppose it depends on the vehicle.
We didn't have any cameras; just nosy neighbors (really, just one massive busy-body). I'm all four ratting out people who have been warned over and over again to clean up after their pets, to stop dumping commercial garbage in the dumpsters, etc., but I have no problem with people being slightly outside of the letter of the bi-laws, so long as their not making a mess or otherwise causing a disturbance.
In this particular case, I don't make a mess, but I'm not sure that it would matter TOO much, anyway. There are a couple of cars leaking oil more than I would ever spill over a lifetime of changes, even if I dropped a drain plug into an open container every single time! lol It's not bad, but that's kind of my point.
I like the Fumoto, because I don't have to wear gloves (I do anyway) and there's no real way you can screw it up. It does take longer to drain. As I mentioned, I typically slide the pan under, open the ball valve, verify the drain stream is not going to get outside of the collection pan, and then walk away for half an hour or more.
I also haven't taken a sample for UOA in a while, but wit a drain plug I was never able to do so without making at least a little mess. Now, I could open to drain a bit; close the valve and place the sample bottle under, and then open the valve; then repeat at various points during the drain to get a representative sample. Minimal mess, if any.
Originally Posted By: JHZR2
I ,Ike the concept of fumoto, but have never bought one. Ive found that enough junk is caught on drain plug magnets to keep using them.
I would take a fumoto plus a secondary plug with magnet... doubt I'll see one in any car I own.
I've recently bought into the magnets-on-the-filter craze, as an experiment. Seems like that would resolve your concern.
