High miles oils is thick than dino oils ?
MS
My manual recomment me use 5w/30 on my mustang gt. Its had 130k miles and Im really happy with pennzoils 10w/30 with lucas oils, but in the morning when I start it up, it make a click sound like, lift tick for about 20 second, then it go away. I dont like to go back 5w/30 because 10w/30 is work the best for me, less oils burn and no smoke ( I have valve seal problem ), should I stay with 10w/30 with lucas or go with 5w/30 with lucas for better flow for winter ?
Or stay with what work ?
So you've been using the Pennzoil yellow bottle 10W-30 with a bottle of Lucus oil stabilizer? If that's been working out well for you, than keep using it.
5W-30 is a cold weather oil for like zero degrees Fahrenheit.
Right. Motorcraft oil filters are very good and valved properly for your car. Similar is not good enough.
This fixes start up noise often in modern Fords.
Yes, should I go with High miles pennzoils formular ?
Yes I do use motorcraft oils filter.
Is super tech same as pennzoils and quaker state ?
thanks
I heard good thing about Auto-Rx, will it be ok in my situation ?
I suggest buying a bottle of Pennzoil 10w-30 High Mileage after an Auto-Rx treatment. But don't use the HM oil with Auto-Rx, as per the a-rx directions.
Yes, A-rx is a good product. It won't fix everything, but often times it works as advertised.
