This may be somewhat off topic, but hopefully closely enough related to consumer electronics that I can get a few responses. I know there are quite a few knowledgeable sound people on here. I’m trying to find a “good” layout for my basement sound system. I’ve asked this same question on AVS and got radio silence. Zero, zilch, nada. I’m not sure if this is an unanswerable question, too basic, or what. But I’d appreciate any and all input!.
I’ve attached a picture of my basement which is pretty close to scale. I'm currently setup with Monitor 70 floorstanders (red boxes), and an entertainment center with a Polk CS2 center (green line). The orange stars are where my ceiling is wired for surrounds, but none are there yet. My next project is a sub, which I am seriously considering DIY’ing. Based on the reading I’ve done, one sub has grown into two, I now need a dedicated amp, etc… My head is reeling. I think I may do two 15” Stereo Integrity HT sealed enclosures, but not sure yet.
Anyway, back to my room. My couch/chair is about 14 foot from my TV, and my front speakers are spread about 10 feet apart due to the gas fireplace being in the way. Which leaves the person sitting in the chair is pretty much out of any "sweet spot" sound wise. The chair is OK, but not great.
I'm considering moving the speakers to where the purple boxes are, which would put them 15' apart. It seems like widening them would get me a larger sound field, which should be beneficial. If I do the equilateral triangle thing with string, I have to push the couch back a couple feet. That’s probably ok, I’ve got a Panny 60ST60 . But I’m definitely pushing my couch even further from optimal viewing distance. I'd also move the entertainment center closer to the fireplace to center it between the new speaker locations.
Thoughts? Will this help, or am I just creating a new problem in an attempt to solve an existing one? I’m not 100% sure that having my speakers spread so wide is a good thing. And they are going to be close to the wall, which isn’t optimal. But unless I tear out the fireplace (wife isn’t buying that) I’m pretty much stuck with less than perfect layout. I'd thought about spinning everything so it faced the bar, but then no one in the rest of the basement could see the TV. I pretty much have to have it where it is.
