Originally Posted By: Ken2
Rob,
I'd clean the transmission with Auto-Rx and then flush and refill with your choice of any top quality ATF recommended to replace T-IV. Amsoil is excellent, but it isn't the only one.
You might read the paperwork you got with your extended service contract. (It is not a warranty.) That will describe exactly what you must do to keep it in force. The choice of ATF isn't a big deal as I see it as long as the ATF meets or exceeds T-IV performance. They're all red and no tech will know what brand or what pedigree of ATF you're using.
Unless the service contract specifies that you must get all work done at a Toyota dealership and use only Toyota parts, then you can get required work done at any place not prohibited by the fine print in the contract. (No, the Magnusson-Moss Warranty Act does NOT apply, 'cuz the extended service contracts are not warranties regardless of what the salesmen call them.)
I agree basically, but would not put the needed 1K miles for an Auto-Rx cleaning on burnt ATF. I'd get some SuperTech ATF speced for your car and maybe go 2K with an Auto-Rx cleaning and then flush and go with a top rated synthetic.
A Magnefine inline filter would be a good addition also. I have one on my Camry and Jeep Cherokee.
