i opened up a federated, i used a coping saw i recently bought (the guy at meijer suggested it'd work to cut open a hastings filter) and it had only 30 something pleats, similar to a fram, but it did have a legit antidrawback valve, it seems slightly better than a fram orange but in the same league, and when i opened it up for a 2700 OCI, some of the pleats weren't straight and were bent, whereas i opened up the mighty filter on the taurus the quick lube used and it was a 6k oci on conventional (yes, went over) and none of the pleats were bent/collapsed and it had like 60 something, way more media, and the adbv was also black or rubber rather than the red/silicone that the motorcraft uses, which is what i put on the taurus
so it seems you get what you pay for, the quick lube place servicing the taurus cost 35 dollars and the filter was a mighty, which i heard was similar to s purolator and it held up well, despite going over the normal OCI!
whereas, for a short OCI, the federated OCI didn't hold up as well, it did its job, and it wasn't entirely collapsed, but you started seeing some of the pleats collapsing/not working and it had less media, but it had a coil spring, and no carboard end caps, so its "better" than a fram, albeit not by much
