From what I can tell, considering they both have essentially identical volatility, the only ingredient difference is additive package. Every UOA I've seen that had both oils showed the contest was a draw. I'd bet that in engine test sequences, the performance is slightly different but it would take tests like that to differentiate their performance. I'd guess that some engine's seals (valve seals) prefer one oil over the other since detergent package has a large effect on seal properties; i.e. some engines would probably burn less oil with one over the other. Only way to know is to try both oils.
