I have a set I made from 1 guage and reused an old set of juper cable ends. I have jump started catapilers with it and while they got a tad warm they held together just fine. Old Welding cables work good too.
The set I gave my Dad about 15 years ago are 3 gauge and 36 feet in length. Keep in mind I worked as a Mechanic for a short time and worked in Heavy Equipment and Salvage prior and dureing college off and on. Ihave no idea today where you might find a good set of cables beside going to a place that specilizes in commerical fleet supplies or SNAPON or MATCO etc..........
If you can try to get ones with either silicone or virgin rubber insulation and the thicker the better. Cracking is the main reason welders chuck their cables for new ones but you can paint plasti dip on them or use heavy duct tape on them to seal them up and you could not get anything cheaper that heavy.
I wouldnot go any smaller then 4 guage stay away rom those elcheapo 8 guage and smaller ones!!!!! If you own anything made by GM havine the side post gripping ends is always good too!Unless you are a moron stay away from the ones that protect from reverse polarization. You could buy the needed monster diodes yourself and modify them to prevent reversed polarity. I do it to all my CB radios to protect them from idiots wireing them up backwards!
