I have a 1980 Mercedes 450SL, and after reading everywhere that AutoRX is great, I'm actually convinced (it has takes some days of reading to convince me, having had bad experiences with other additives in years past).
My engine runs well, but is leaking oil, particularly out of the rear seal. I don't know if the seal is torn, and as it costs nearly $1000 to replace, it seems spending a couple hundred on AutoRX treatments is warranted first.
QUESTIONS:
My car takes about 9 quarts of oil so I'll be adding 18 oz of ARX with a clean oil change and then driving 2500 miles.
Some people have indicated that you should change the filter at least once in the first cleaning cycle, though the ARX site does not mention this. Should I? I'm think that a filter change at 1200 miles, and then top off with fresh oil and more ARX.
At 1500 miles, I'm going to put 6 oz in the transmission. Then back to JiffyLube 1000 miles later, for the oil/filter on the engine to start the rinse cycle, and a complete fluid exchange for the transmission.
So, now a rinse for the next 3000 miles. ARX indicates changing the filter only at 1500 miles. Some places I've read indicate people changing the filter as frequently as 250 miles during the rinse phase. Should I? Any real benefit?
After this rinse, then do one more complete cycle of cleaning, then rinse.
After this final rinse, I'd like to go to a synthetic oil, though the ARX site indicates that this may cause additional leaking. What if I use a heavier weight synthetic, like Mobil 15W-50?
That mainly leaves my power steering (which I am probably going to have rebuilt due to play in the steering box), and my fuel injection.
Is there a good fuel system cleaner? An AutoRX for fuel injectors? I have CIS fuel injectors, which can't be backflushed (i.e. only replaced with new ones when fully clogged) but I'd like to try cleaning in place.
Thanks for any comments
Andy
http://www.my450SL.com
QUESTIONS:
Andy
