Originally Posted By: Phishin
There will always be microscopic deposits. Always. I don't care what oil you use or how short of an OCI you have, there will always be wear and there will always be deposits. No oil's high level of detergents are going to prevent acids from being present (detergents NEUTRALIZE the acids, not prevent them....therefore acidic byproducts cannot be totally avoided, but their quantity can be diminished with high levels of detergents), and no amount of dispersants is going to carry away all of the deposits. Therefore, as deposits form, there is always a chance that the deposits will contain wear metals present in the oil.
I'd be willing to bet if someone was crazy enough to change their oil every 500 miles in a new car (so deposits, varnish, and wear metals are at a steady state), after the break-in miles, you wouldn't see all these "spikes" anymore.
Well stated. The second you turn the key there'll be wear, combustion by-products, etc. going into the oil. Replenishing the oil with fresh new oil will do some cleaning. Don't forget there is always old oil remaining in the engine with deposits etc. in it, which you'll never get out when you change the oil. Depending on the engine and sump capacity it could be quite a bit. That oil instantly mixes with the new fresh oil, any wear metals in that old oil is tossed instantly into it. Combine that with some additional cleaning from the fresh oil, and guess what......
I'd like to see the results of the 500 mile crazy OCI you mentioned, I wonder if it has ever been done?
Didn't Phishin say?
Quote:
...So, detergents aren't really doing any cleaning. They are prevent deposits from forming...
IF the above was all true, all engines no matter what type of oil and at what OCI, would have heavy deposits at high miles. We know that it is not true. The trucking business would not be able to rack up millions of miles on their engines and even the grocery getters would suffer from excessive deposits because per the above theory, the oil would not clean up anything, but only neutralize the acids, so the buildup would continue to grow with miles.
This brings up another point. IF the initial spike of wear metals is caused by the left over deposits and left over oil, why does it decrease through the OCI and then spike again when the oil is changed? Again, using the above theory, (oil doesn't clean, only neutralizes) the deposit build up and wear metals would be on an ever increasing slope since the detergents would be less and less effective for neutralizing the acids and there would be left over deposits and wear metals from previous OCIs.
In other words, every consecutive OCI should show more and more deposits and wear metals because of the accumulative effect, again per the above theory, but we all know that the UOA numbers (accuracy is largely irrelevant here, but repeatability is) stay pretty much the same for every oil change done at the same interval.
Didn't Phishin say?
