Originally Posted by Purpfox
We'll be on the same page so to speak. I just built a budget bypass with the wix 50150. Ill be reporting data every 10% of the olm to see how it affects the oil over time.
Nice to see more data streamed posts.
Thanks I appreciate it. I saw your thread and I'm looking forward to your data as well. You will have significantly more data points at significantly shorter intervals between samples than me, but it will be cool to see how the two compare on drastically different vehicles. Based on my full flow filter appearance after 5,000 miles my engine generates a lot of junk, but I suppose it's entitled to after nearly 342,000 miles. I'm currently only at about 650 miles on my bypass setup, Frantz recommends changing the first element at 500 miles which I didn't do. I'm planning on running till the filter stops getting warm, if that hasn't occurred by 5,000 miles on the filter I'll pull a sample at that time.
Cheers.
