Hey guys, a month and a half ago I purchased a 01 focus for 500 bucks that had a bad clutch. The car has 83k, and the interior is perfect. The outside has a couple scratches nothing major, and I had to replace the fuel cap cover that I got at a junkyard for 10 bucks the same color.
Well anyways, heres to the point. I was able to replace the clutch (oh what fun that was,) it is a MTX-75 transaxle. Manual recomends Mercon, but then ford changed that to thier ford manual transaxle fluid synthetic. I used Amsoil Sythetic 75-90 transaxle fluid that was recomended, was cheaper than the ford stuff.
I had to destroy the lower ball joints on each side because they were seized onto the knuckle. I put a pickle fork on them and used a sledge hammer and disconnected them. I replaced the balljoints by using a angle grinder and drilling out the dead bolts. I replaced them with Spicer balljoints made by DANA that are who makes the ford OEM joints for this car.
I repalced the coolant with ZEREX and distilled.
Used the turkey baster method and replaced the PS fluid with Val. Maxlife Dex/Merc ATF.
I had to replace the shifter cable that broke upon removal (bad design, very bad design.)
I replaced the fuel filter with a NAPA gold one, and the Cab air filter with a STP one. And I dumped a bottle of techron in it with a full tank.
Car has been running great for a few hundred miles now.
But it does have a couple of problems. The steering wheel is off center and it pulls to the left. The radio turns off and on by its self and does not work well with cds at all. Other than that it is good.
What suspension parts could cause the steering wheel to be misaligned so I can replace it before I get an alignment.
Thanks.
Thanks.
