Originally Posted By: wiswind
I looked the catalytic converter up on rockauto for your '94 3.2L SHO.
They list the direct fit Walker, looks like they do 2 converters for the replacement.
It is $374.79 (US).
I put a Walker Direct fit on my '96 3.8L windstar, while not as good as a OEM, it did the job for a number of years.
Walker is a good name in the aftermarket.
No one around here stocks it for the SHO, so I ordered the walker cats from rockauto on Tuesday. I had the 5% discount code which brought it down to $356.05 and Walker has a mail in rebate for $30, so effectively i'm paying $326.05 + shipping for 2 good converters and new y-pipe. A good deal, because I didn't just want to weld in 2 new universals, and might have had a poor fit because of the converters in the y-pipe in the FWD v6.
Rockauto also has the Motorcraft upstream oxygen sensors for $37.79 or $48.79 (US) each.
You have 2 upstream sensors.
If you get a code showing 1 sensor failing, you could switch the 2 sensors and see if the problem moves, to see if it is a sensor failure or a actual condition being reported by the sensor.
At this age, if I were replacing 1 sensor, I would replace both sensors...Reason, then you have a matched pair.
Oxygen sensors switch slower as they age, and having matched switching speeds will give you a more ballanced condition between the 2 cylinder banks.
I already replaced the sensors right when I discovered the code as per an above post. They are both new, and matched pair, with OEM exact fit for the car.
If you are not a member of a SHO forum, I would recommend that you find one as this is a good way to be on top of things for your specific vehicle.
I recommend this for any vehicle that one plans to keep.
I'm on SHOforum and TaurusClub, but here on BITOG replies come quicker, and seem more knowledgeable. For example, I posted on Taurus club about my Low beams not working, but daylamps and highbeams work fine. Fog lights weren't working either. I even changed the lightswitch with a good working one, and still had no power to the low beam pins at the sockets, even after changing the relay and checking the fuse. Someone on TaurusClub said:
"Maybe your low beams are burnt out."
Well, no power to the sockets, How can that be? Plus my Fog lights aren't working either. Looked in the service manual, and saw that there is a headlight dimmer in the multifunction switch, so I changed that and they all worked great again.
Not every forum can hit a good response like BITOG.
Now Explorerforum is great. Allpar is great too. Stratusphere, not so much. They're more into mods then problemsolving.
If you change the catalytic coverter yourself, use extra care with any "flex" pipe.
They recommend you support the flex pipe with a wire....and not let it dangle.
Preventing extra flexing will prevent it from being damaged and causing you yet another part to replace.
Yup, knew this already. It looks like it's leaking already though. Plans are to install a Dynomax Catback or Borla Catback sometime next year.
