You might want to switch over to M1 0-20.
Why?
For a new Toyota I4, using M1 0-20 will give equal performance IMV, very easy to purchase, and cost probably is less if that is a factor.
It won't give equal performance since it's a heavier oil and massively so on start-up plus it's more shear prone. If one wants to run an oil with greater high temp' protection (I'm not saying it's necessary for street use) than the spec' high VI 0W-20 simply add a pint or two of M1 0W-40. This will give you a higher HTHSV than M1 while still being lighter on start-up.
Massively heavier? Good lord, I can't imagine what adjective you'd use if you were comparing TGMO to a typical 5W-30 oil. M1 0W-20 is more shear-prone than TGMO? Based on what?
Why?
