As promised, the service report from Champ.
Complaint: Reportedly the filter collapsed during service. Major engine damage was reported.
Test Results:
1. The nylon core is broken and media has collapsed inward. Previous lab testing indicates a differential pressure in excess of 70 psi required to damage this type filter in this manner.
2. This engine should be equipped with a bypass valve that opens during periods of high differential pressure. This bypass valve has obviously failed to function properly.
Note: There was nothing found which indicated the filter was defective. The filter has been in service on an engine that malfunctioned.
OK. So now you have Champs response.
I'm going to request the filter be sent back so we can cut it apart and take a couple pics to post so everyone can take a look.
Now I have two questions.
First question.
On the Champ Ecore website they have a Frequently Asked Questions section. One of the questions is "Is the plastic center core as strong as the metal core that was used in the past?" Their answer is "Yes, the glass filled nylon core is twice as strong as the steel core it replaces." My question would be then, how were we able to have run this motor for 3 years with the steel cored PF1218 and not have seen this type of failure? Again, for the recored, we have not changed a thing in this motor, the oil pump, the oil we use and the way we drive and operate the car.
Second question.
Again, from the Champ Ecore FAQ section. "What is the max flow rate of your new filter design?" Their answer is "The nylon core on the new design contains more open area than the old the old perforated steel core. This results in less flow restriction across the element assembly." My question would be, given the excellent past 3 year service record we've had with the old steel cored PF1218, balanced against the information that Champ delivers in their FAQ section, why should we have not considered using the new design oil filter if it has a "twice as strong" core with "less flow restriction"?
Given the information provided by Champ on their website about their new oil filter design and your previous experience with a part number, what sort of decision would you make?
FYI...GM Performance has a video clip of a 572 in service. Just curious about what filter they're using?
http://www.gmgoodwrench.com/perfpartsjsp/home.jsp
Thanks to everyone for contributing their comments and opinions. This has been a great learning experience.
