Diesel Fuel Additive Recommendations
quote:
Originally posted by Bror Jace:
I've always wondered if power service was any good. Thanks for the anecdotes, Intelman34.
No problem. I should add, that its very cheap and EASY to find. Heck even Wal-Mart carries the "Diesel Kleen" and they also carry the winter versions (White bottle and only adds 4 cetane points).
My girlfriends father has been a semi driver and diesel mechanic just about all of his life and has used nothing but Power Service. You really can't disagree with a person who has used it for increased mpg, anti-gel, and lubrication with awesome results for 25+ years and millions of miles.
quote:
Originally posted by Intelman34:
Do they have Power Service by you?
I use the "Diesel Kleen +Cetane Boost" every fillup in my 5.9L 24v Cummins Turbo. I see a 2-3mpg increase as well as a great improvement in power.
I used to use this in my 2000 powerstroke but started using Amsoil and tried Stanadyne for 60 gallons. Only the Amsoil got rid of the #8 injector ticking sound.
Just got some independent lab tests from Odis on Fuel Power for diesel fuel treatment and thought I would share it here. Hopefully soon LC and FP will have a web page with this kind of data.
Petroleum Specialist Lab, Ft Worth TX.
Fuel from pump locally procured. So its realistic to what you as a consumer would see.
Freeze point ASTM D 2386
#2 diesel W/FP -20
#2 diesel -17
Volatility testing D 86
Distillation residue vol % FP treated 1.1
" " #2 diesel 1.3
Limit is 1.5 %
Distillation loss Vol % FP treated 0.1
" " #2 diesel 0.4
limit is 1.5 %
What this means is that FP is very compatible and stable in the diesel fuel application. 1 oz to 5 gallons gives significant cleaning and stability with a benefit in cold weather ops, with less buildup in injectors and CC. While adding needed lubricity and at a cost significantly less than ANY additive mentioned above or available.
Contact Rugerman1 or Odis Beaver for more data.
[ October 12, 2003, 04:09 PM: Message edited by: Terry ]
